Drag Racing Tech
Am I capable of 12s?
Old 05-26-2002, 02:45 AM
u8dusst's Avatar
Default Am I capable of 12s?
Last night I went 13.6@107 with a shiddy 2.3 60'.
Heres the timeslip line for line.
Reaction: .458
T1: 2.310
T2: 6.095
T3: 9.046
MPH (T3) 83.723
T4 11.554
ET 13.675
MPH 107.077
What are the most effective launch techniques for our cars? BTW im running stock SS wheels with regular PSI.
Old 05-26-2002, 04:25 AM
AlonzoVersion 1.0's Avatar
Default Re: Am I capable of 12s?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by u8dusst:
<strong>Last night I went 13.6@107 with a shiddy 2.3 60'.
Reaction: .458
T1: 2.310
T2: 6.095
T3: 9.046
MPH (T3) 83.723
T4 11.554
ET 13.675
MPH 107.077
What are the most effective launch techniques for our cars? BTW im running stock SS wheels with regular PSI.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not sure about the launch but I would get some nitto drag radials and heat the f*ck out of them and lose a few pounds off the car.That 60 is hurting you bro.But I beleive you can do it just get some more wheel time in your car.Oh and when you drag race over inflate the front tires and play with the air pressure on the rea to see what the car likes and pull out you airfilter floor mats etc...you will get it oh and your antenna as well.Every little bit helps.
<small>[ May 26, 2002, 04:26 AM: Message edited by: The Booker man ]</small>
Old 05-27-2002, 06:36 PM
mykdiver's Avatar
Tell us more about the car, mods? M6 or auto? Steet tires? aired down? Temp? altitude? Traction? Etc...
Old 05-27-2002, 07:51 PM
u8dusst's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mykdiver:
<strong>Tell us more about the car, mods? M6 or auto? Steet tires? aired down? Temp? altitude? Traction? Etc...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Only mods are FRA and descreened MAF. M6, street tires on SS wheels, regular pressure, temp was around 80, sea level, and I think my 60' explains my traction. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 05-27-2002, 08:16 PM
98TAauto's Avatar
ill help ya with what to do on tires..
put 26psi in them, and 44 up front(helps weight transfer)
make sure you go around the water box!! do not get those tires wet. Once around water box, just drop the clutch and do a small 2-3 sec spin up to the tree.
you dont need to heat stock tires, just clean them off. Ill leave the launching to the M6 guys in here.
Old 05-27-2002, 09:47 PM
LSs1Power's Avatar
I'm having the same problem with my 60ft times. I have the stock GSA's and they are very bad at traction. My best 60ft was 2.10 and i got that by spinning a little bit of the line. I think i had the RPM around 2K and then i slipped the clutch. I think if u do the same move u will get better traction due to ur 17 SS rims with the 275's in the back. Its a good idea to lower the pressure in your rear tires too. 26 or 24psi is good. Lower than that i think it might affect ur trapspeed, but might improve ur ET time by reducing ur 60ft.
Old 05-28-2002, 01:25 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LSs1Power:
<strong>I'm having the same problem with my 60ft times. I have the stock GSA's and they are very bad at traction. My best 60ft was 2.10 and i got that by spinning a little bit of the line. I think i had the RPM around 2K and then i slipped the clutch. I think if u do the same move u will get better traction due to ur 17 SS rims with the 275's in the back. Its a good idea to lower the pressure in your rear tires too. 26 or 24psi is good. Lower than that i think it might affect ur trapspeed, but might improve ur ET time by reducing ur 60ft.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorrybro but the GSAS are never gonna hold anypower.Maybe a mustang. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 05-28-2002, 03:10 AM
u8dusst's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98TAauto:
<strong>ill help ya with what to do on tires..
you dont need to heat stock tires, just clean them off. Ill leave the launching to the M6 guys in here.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I did everything you suggested, and how dare you think im stupid enough to drive through the water box. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Im running again on wednesday, ill lower the pressure this time and see what happens. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Thanx guys.
