TREX and G5X2/3 CAM Q's!
Im sure this has been went over before, and I have done many searches, but still have no CLEAR answer to these Q's. Can you run a Trex cam on a stock shortblock and heads? How bout the G5X2 cam? How bout the X3 cam?
Thanks fellas!
Thanks fellas!
Yes, all three of those cams can be run on a stock shortblock/heads. You'll DEFINATELY need a top-notch valvetrain setup, however, if you expect your stock shortblock/heads to hold up to these monster lift camshafts.
Originally Posted by Ravenous T\A
From what I understand the X3 needs to be the 114LSA, the 112LSA needs the pistons flycutted for room for your valves.
This is incorrect...the X3 on a 112 does NOT require flycutting, UNLESS the heads have been milled OR you are using larger than stock valves. In this case he was asking for a stock headed car. The X3 will fit with no problem, on the stock heads. You will need to upgrade your valvetrain for the high lift cams.
