tbyrne
07-01-2004, 11:03 AM
http://www.tbyrne.com/Images 2/strange12boltinfo.jpg
3 or more orders are required by Wednesday, July 14th to receive the following prices -
PRG210 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10 $2129.99 (regular price is $2299.99)
PRGOP8 Upgrade to US/Strange 33 spline Super strength posi-unit (with ABS sensor at the axles - usually for traction control cars) $145.00
PRGOP14 Upgrade to US/Strange 33 spline Super strength posi-unit (with ABS sensor on top of pumpkin) $145.00
PRGOP10 Upgrade to aluminum support cover $115.00
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars.. $229.99
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
Have a good day,
Tom
http://www.tbyrnemotorsports.com/Banners/camarobanner.gif (www.tbyrnemotorsports.com)
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
Price Match Plus policy (http://www.tbyrne.com/pricematch.htm)
Have a good day,
Tom
