Harlanf Sharp 1.8 RR are junk!
Just to let everyone know that doesn't already, the Harland Sharp 1.8 RR hit the heads when they move through the motion. I have had to clearance my RR just so they don't hit the heads. I have photos of this happening and the shavings left afterward. I was told by Nate (nasty performance) that I would have to clearance the valve covers before they ever got here so I expected that. I cut on the valve covers, broke through a couple times, no big deal, JB weld took care of that. But, after I cranked the engine a few times with the valve covers on I pulled the valve covers back off "just to make sure" and I see shavings all over the rockers! Thats just bull ****! I bought these new and recieved nothing with the rockers that said I might have to "clearance the rockers" themselves, I appreciate Nate telling me ahead of time that I needed to clearance the covers (thanks Nate), I have no problem with Nasty, just Harland Sharp! I've done a lot of performance work on engines but never had an issue like this with something that is supposed to work with no modification when I bought it. Just had to vent!
Scott
I don't know how to post the pics otherwise I would!
Scott
How does failure to clearance the rockers make them junk?
Any aftermarket part like this should be checked for all clearances regardless if they're supposed to fit w/out issue. It comes with the territory with any of these type of modifications. Even "supposed" to fit aftermarket cranks require unexpected clearancing that is picked up on pre-assembly.
You are correct, aftermarket parts need to be verified for fitment, but this was obvious error! Obvious because if they (HS) actually checked them on the heads there is no way they could think they would fit correctly without the customer having to grind on their product to make them work. Obviously there's nothing you will say to make me feel better toward thier poor quality. I will not every buy their product again and thought a few others might like to know that theres a chance they will buy these things and possibly have problems. Better yet, don't buy their products! BTW, I haven't heard of anyone having problems with "other" companies roller rockers!
Scott
Scott
SN95 Director
Scott
Scott
Sorry jrp, I guess I didn't realize that since I was installing aftermarket parts I have to lower my expectations out of the companies I buy from!? Thanks C4vetteLS1, I simply wish I new that they didn't fit 98's sooner, I wouldn't have bought them. I have them now and and after clearancing they seem to work fine, so hopefully I can get to the track sometime soon and see what all the new upgrades are worth.
Scott
Scott
Every head casting is a little different that is the first I have heard of any clearance issues. I have sold and installed about 100 sets and plenty on the 98 cars and the only clearancing I have done is to the valve covers. I am sorry for the problems but your car is just slightly different than most. With that lift cam and 1.8 rockers you had better have some great springs in there to keep it from float. You are pushing the P/V clearance.
Nate
Nate
Well Wolfee has the right to be upset. Same was with Comp shaft rockers. "Fits under stock valve covers" they said. Yeah right, which ones?? C5R !!!
R&D should include different castings and products be labeled as such.
On the other hand, no aftermarket parts should be taken for granted to "fit" and all clearances should be cheked IMO
Nate
Nate
I also had to clearance my Jesel's from hitting the retainer with the my larger diameter springs, its not a big deal just need to look for stuff like that when you are assembly, just because it goes together with bolts doesn't mean its just "bolt-on and go" IT's not HS's fault every car has some variance one way or another no matter what parts you are buying. Thats the first complaint i have heard with HS. I got some friends that swear by HS on their SBC's
It's funny how things get twisted from the valve covers to, now it's the springs hitting The problem is not the springs, it's not the valve covers, like I said before, Nate told me that the covers will need to be clearanced, no big deal! The rockers are hitting the actual head casting, could someone please post some pictures for me, tell me where to send them. It's also funny that we as an aftermarket comunity consumers have been "trained" to expect aftermarket parts to not work as they were designed, and yes, someone actually gets paid in most cases to make sure the parts work correctly and have a little extra clearence to accept variations from the OEM manufacturer. And I HAVE been around aftermarket performance engines for quite sometime. In the circle track series I'm a owner/driver in I have even built a few of my own BGN motors, as we have the same rules (old 9.1 390 carb style). Talk about issues, you have to check EVERYTHING on those engines, but I expect it from those engines, not the simple bolt-ons that I buy from my semi-stock street driver! At this point the subject has kind of been beat to death, rip me if you want but I expect a part to fit when I buy it.
Wolfee
Wolfee
Wolfee,
Every thing you say is true and it is ridiculous that this stuff never seems to be right out of the box. I don't know if they don't actuall try many heads but they are NOT doing their research!
Wolfee, I have installed these on 97/98 heads and it is true, you have to grind a huge amount off the rockers and covers to make them fit. It was a prototype setwe had last year from LS1 Source we put on Brians car. I even think they might have been 1.9's, I'll have to look in the folder. Definitly use these on 99 and up heads!
Wolfee, to post up pictures, when you post a message, look under the "Submit Reply, Preview Post" buttons, in the "Addition Options" area. There should be a button that says "Manage Attachments". Click that, and you can attach files. They won't show up as pictures in the post, but as links to photos hosted on LS1Tech. When they click on the link, the photo will show up. What you'll be doing is uploading your photos to the LS1Tech webserver to be hosted. Hope that helps. PM if you need any help with this.
