Patriot 5.3 truck heads exhaust leak?
Old 07-04-2004, 12:29 AM
TNormZ28's Avatar
Default Patriot 5.3 truck heads exhaust leak?
The "Patriot" stamp on the head is creating an exhaust leak. I did a search and saw where JB Weld should fix this but just curious if anyone else had this problem and if you did use JB Weld to seal this up, and how well this worked? We are fixing to bolt up a ProCharger and the leak will only get worse. These heads have been on the car for awhile and you can obviously see where they leaked. We'll call Patriot about them but I was just curious what those with similar problem have done effectively. Thanks in advance.
Old 07-04-2004, 08:48 AM
TVWilkes's Avatar
Others have told me this caused a leak with them.We no longer put the logo on the side of the heads.
Old 07-04-2004, 08:58 PM
Ryan02SS's Avatar
When I got my heads I noticed that and it kinda puzzled me as to why Patriot would locate their logo there. So far mine is not leaking. Knock on Wood!
Old 07-04-2004, 09:35 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
I had one set leak, but I had a set of non-metallic gaskets (Pacesetter) left over from a header swap, and I installed them and sofar no leaks.
Old 07-04-2004, 09:46 PM
TNormZ28's Avatar
Do you know of anyone that had this problem on a boosted motor and used JB Weld successfully? thanks.
Old 07-04-2004, 10:04 PM
TVWilkes's Avatar
JB weld will fix it.
Old 07-04-2004, 10:22 PM
SPANKY LS1's Avatar
Seems reasonable. Plop down $1000+ for new heads, and before you install them, JB Weld the outside of them so you don't have an exhaust leak.
Old 07-04-2004, 11:27 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The heads don't have these logos anymore. There wasn't very many Patriot heads shipped with the logo on the side of the head.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-05-2004, 12:56 PM
M6HuggerSS's Avatar
i think everyone should get there heads properly VACUM tested before you install them! it only takes a few minutes and can save you alot of time and money and low numbers in the future! VACUM TEST ALL YOUR HEADS!!!!
Old 07-05-2004, 03:04 PM
-Joseph-'s Avatar
Last I heard all Patriots are now hand lapped in & vacuum tested.
Old 07-05-2004, 07:31 PM
TVWilkes's Avatar
The leak is an exhaust gasket leak,not a exhaust valve leaking.
Old 07-06-2004, 06:26 AM
racrx's Avatar
Oh, well sinse it is only an exhaust gasket leak, all is forgiven.......JUNK!!!!!!!!!!!!
Quick Reply: Patriot 5.3 truck heads exhaust leak?
