LSX vs LS6
Old 07-05-2004, 06:31 PM
HmyThaClwn's Avatar
Default LSX vs LS6
hey guys what should i do? this is what i have already done......i want to EVENTUALLY get new heads and cams when the warranty runs out...so which should i get? also 78 or 90mm with the LSX?
David
Old 07-05-2004, 07:19 PM
99CamaroSS_'s Avatar
if your going to do heads and cam definetly get the LSX if your just gunna do bolt ons then ls6. i saw a 18+Hp gain from my LSX. and im a Cam only car. no heads. and this was a 78mm. if you going to be doing a lot of power i would say get the 90mm and 90mm TB. but if not.. get your Stock one ported and put on the 78mm LSX i would say from a stock ported TB and 78mm LSX you will see 25+ RWHP thats just my .02
Old 07-09-2004, 12:23 PM
HmyThaClwn's Avatar
I will be doing EVERYTHING possible....eventually....but i have 3 yrs left on my warranty.....so i cant do the heads and cams so would the 90mm lsx and tb be ok, until i can get heads and a cam?
Old 07-09-2004, 12:27 PM
SmokingWS6's Avatar
Thumbs down
FWIW, the $$$ amount of the LSX over the Ls6 isn't worth 1hp and 5lbs of tq. From experience, two people i know who have got them had fit problems. One had severe misfiring due to a manifold leak affecting a few cylinders. Also, they are made out of plastic instead of composit material.
JZ'sTA's Avatar
The 90 will still work but probally wont gain you much HP.
You are lookimg at 1300 dollars for that setup.
I would say invest in a rearend or wheels and tires for the track.
Old 07-09-2004, 12:52 PM
is his car is an ls1 manifold... going from an ls1 manifold to LSX you will see a dramatic gain. i saw 18+ horses from mine. which i was very happy with. i might be doing heads sooner or later but im just sticking wit the 78mm. if i were you i would buy the 78 and then later on when i get heads and Cam just get the 78mm one Ported. thats my .02
Old 07-09-2004, 01:22 PM
NKAWTG...N
StoleIt's Avatar
silverghost has a ton of problems with his lsx, it was warped and then he had a very very hard time returning it under warrenty. he had a hell of a time with it, so good luck.
Old 07-09-2004, 02:51 PM
SmokingWS6's Avatar
Yeah, I ment LS6 vs LSX.
Old 07-09-2004, 06:21 PM
Moderator
davered00ss's Avatar
78mm LSX. just my .02
Old 07-09-2004, 07:15 PM
Biomechanoid's Avatar
I was asking a similar thing a few days ago-based on the various responses and people's personal experiences... For my HP/TQ goals, the extra cost of the LSX over the LS6 intake is NOT justified. then again, I'm only looking to put down about 420HP/400TQ N/A when my project is done. you're probably looking at a much higher goal and might need the extra numbers the LSX has over the LS6.
Old 07-10-2004, 02:57 AM
Third Gear's Avatar
Yeah, CHP has been doing a bunch of dyno tests recently on LS1s and the LSX is only giving around 3-8 HP/ 3-4 TQ on an engine dyno over the LS6... not worth almost $800 IMHO.
Old 07-10-2004, 03:20 AM
LS1Baron's Avatar
Why are you worried about the factory warranty? Go with the 78mm LSX. The LS6 is nice, but the LSX is easier to port for a nitrous system.
Old 07-11-2004, 10:18 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The good part about the LS6 intake is we sell them for $360. That's alot less $$$ than the LSx.
As far as hp differences, we've seen a additional 8rwhp with the LSX on a cam only car...
You could always buy a ls6 & sell it when you upgrade... I really think a used ls6 intake sells for $300, so you could always sell it if you decided to go with with the lsx.
It's a hard call between the two...
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-16-2004, 11:54 AM
HmyThaClwn's Avatar
Thanks Guys For All Youre Input.....i Think Im Going With The Ls6 And Just Leave The Tb The Way It Is....sound Good?!?!
