Trans mount
Old 07-05-2004, 09:13 PM
ArticLS1z's Avatar
Default Trans mount
Whats so special about the 98 camaro trans mount that no one carries it....
ended up getting a univ. energy syuspension .. and now the car vibrates like crazy intrerior rattles and car gets all kinds of false kr... only reason i put it in was the dealer was open today and it was completly ripped in half.. so looks like ill be pulling this one out and getting a stock one tomorrow.
any ideas why it's vibrating so bad?
Old 07-05-2004, 10:29 PM
LS1Tech Co-Founder
Nine Ball's Avatar
The harder polyurethane ones do not absorb vibrations nearly as well as the softer rubber ones. But, the poly ones are much more durable and prevent the tranny from moving, which will help you transmit more torque to the rear end.
But, like most mods, there is a trade off involved. More durability, and unfortunately more road noise and vibration.
The '98 tranny mounts aren't anything special, any 98-02 will fit.
Old 07-05-2004, 11:04 PM
felton316's Avatar
I know the AutoZones around here carry the rubber mount.
Old 07-05-2004, 11:16 PM
ArticLS1z's Avatar
the rubber mounts they gave me were either 2 bolt lower or didnt work with stock hardware and looked nothing like that and the holes wouldnt line up on the trans its self... none of them showed one for a 98 not even napa.... so they were giving me 99up mounts from the computer... this isnt a light vibration.. i have the same mount in my truck and i didnt feel a diffrence... it so bad the whole car shakes 6-7* of kr @ wot...
Old 07-05-2004, 11:19 PM
ArticLS1z's Avatar
Here is the stock one that was torn in half ... the one they gave me was a just a square with a 2 bolts in the center insted of 1
Old 07-06-2004, 08:37 AM
hourang's Avatar
did you torque it down correctly? check if its loose.
Old 07-06-2004, 09:00 AM
Moderator
jimmyblue's Avatar
The poly mounts may need to be shimmed or
have the shim washers left off, to get the
tailshaft angle (counterpart to pinion angle)
right. Too high and it will add vibration & scrub
to the tailshaft U-joint. If you used the washer
or plate that came with the mount, try taking
it out and see if things improve vibe-wise.
Search it up in the Automatic Transmission
section for much more info.
Old 07-06-2004, 05:54 PM
ArticLS1z's Avatar
Well i went to GM today and got a stock mount.... car feels great no vibrations at all.
Old 07-06-2004, 06:48 PM
GM Muscle's Avatar
You need to grind the hump off the ES mount to get it to work right. If you didn't grind the hump off that is probrably what's causing all the vibration. I didn't use the plate either.
Old 07-06-2004, 11:38 PM
ArticLS1z's Avatar
ah ohwell .... already returned it..... if it happens again ill try the ES again
Old 07-07-2004, 11:28 AM
hourang's Avatar
that sucks, get the Prothane poly mount, it bolts right up, both me and my friend have it.
