Stock Shifter Stick Question
Old 07-06-2004, 07:28 PM
Ru2n00n3er's Avatar
Default Stock Shifter Stick Question
Ok, my stock Hurst shift stick has started to rotate freely, and if you yank on it you can pull it out. There isn't any danger of my pulling it out in normal driving, but it is a little funky to feel the shifter twist a bit when you're driving.
I've got a friend at a dealership who looked at it and according to them the sticks come with a rubber grommet at the bottom end of them that keeps them from rototating/locks them in place. This thing has apparently worn down or broken off which is why it can now move.
Anyway, I'd somewhat looked into the LSS before and figure this might be a good time to do it, since I'd probably pay MORE just to replace the factory version. But from what I've read before(could be wrong) was that the reason the LSS was shorter than the factory one was BECAUSE it didn't have the rubber peice? Is that correct? And it that's true would that stick then rotate too?
Are there any other short sticks out there other than the LSS? Will that work with my Hurst know? How easy of an install is it?
Old 07-06-2004, 07:47 PM
WS6WRX's Avatar
The install is cake, 2 bolts, they are shorter cause that's the point and it won't rotate cause it's bolted right to the shifter w/ out any runner. BTW if you want a stock Hurst stick for cheap, lemme know.
Old 07-07-2004, 09:39 AM
AGRV8D's Avatar
where can you buy the LSS at?
Old 07-07-2004, 10:40 AM
98Z28MrO's Avatar
Try Afterthoughtsauto.com over there ------>
Old 07-07-2004, 10:54 AM
chupr0kabra's Avatar
The LSS doesn't have any rubber piece on it, but it is considerably shorter than the stock, regardless of that. I have one on a stock Hurst and I love it. I'm a total idiot with tools, but it took me about 15 minutes to change the whole thing out.
I mounted mine "backwards" with the Hurst shifter, because it's more comfortable for me that way. It made a world of difference. Throws are much tighter and more secure, and I never miss now.
-Mike
Old 07-07-2004, 11:09 AM
sscamaro02's Avatar
I second that. I put the Lou's short stick on my factury Hurst also. It makes a world of difference.
Old 07-07-2004, 11:48 AM
Sanders's Avatar
LSS on the factory Hurst is a great combo.
Old 07-07-2004, 12:49 PM
KALEL's Avatar
better than a pro 5.0 or b&m?? can you put the LSS on either of these??
Old 07-07-2004, 12:51 PM
Ru2n00n3er's Avatar
You can put it on the pro 5.0, but you just have to order a different version I believe.
Old 07-09-2004, 03:35 AM
Gamble's Avatar
I love my Pro 5.0 LSS combo... Never missed a gear!
Old 07-09-2004, 09:38 AM
hourang's Avatar
yeah mine did the same you could pull the shifter out, the lss mounts direct to the hurst shifter instead of having that rubber thing on there. i used to miss 3rd all the time, now im surprised when i miss it.
Old 07-09-2004, 11:41 AM
Keenov's Avatar
You can put it on the pro5.0 tower shifter. No different version.. Afterthoughtsautos just sells the pro5.0 and LSS as a kit, instead of having to buy them both and wasting a shifter stick/money.
Pro5.0 + LSS is an awesome combo
Old 07-09-2004, 12:03 PM
Ru2n00n3er's Avatar
What is the actual benefit of the Pro 5.0 over a factory Hurst shifter. I mean I understand the shorter stick because of the shorter throw. But what does getting a new shifter itself help you with. Are they more sturdy? As in less change of breakng stuff with one, which would be why I'd buy one.
Old 07-29-2004, 12:24 AM
BlakeLS1's Avatar
I don't miss shifts right now with my stock hurst so would the whole new pro 5.0 setup be a waste. Should I just go with the LSS to get rid of the rubbery feeling.....?
