times updated
Old 07-06-2004, 08:59 PM
KALEL's Avatar
Question times updated
went to the track tonight. first time since ive been with the new cam...no tuning and i ran a 13.0 at 108 and at 107 with 2.0 60' its better than my 13.27 at 108 with 2.1 60' but the mph has gone nowhere...whats the deal?? the mods are in my sig..
Old 07-06-2004, 09:28 PM
2001 White Ws6's Avatar
Are you still running street tires? If you are then you probably aren't able to get traction worth a damn.
Old 07-07-2004, 04:04 AM
blkZ28spt's Avatar
How did the weather compare to before? Street tires? The ET dropped ~0.3. That seems about right for an untuned cam swap. You should get it tuned, of course, I'm sure that will be a popular/obvious opinion. You should also get sticky tires, but then the stock ten bolt becomes questionable.
Old 07-07-2004, 10:36 AM
KALEL's Avatar
i think it was slightly warmer than the first time i went out... yes i am still on the street tires, but that still doesnt explain why my mph has gone up almost none...
Old 07-07-2004, 10:51 AM
Colonel's Avatar
Lightbulb
Lower density altitude perhaps.
Stock rev limit? You have to be able to shift higher to take advantage of the higher powerband.
Old 07-07-2004, 11:11 AM
KALEL's Avatar
i do have the stock rev limiter...how much of a difference would that make and how high should i set the limiter to? cam specs are 224/230, .567/.572, 112LSA
Old 07-07-2004, 02:02 PM
blkZ28spt's Avatar
If you knew where your power peaked then you would know where to set the limiter. I think you will be wanting to rev it to 6400-6600.
Old 07-07-2004, 03:17 PM
KALEL's Avatar
the cam was custom grinded so im not sure where the power band would be...
Old 07-07-2004, 03:20 PM
necrocannibal's Avatar
You will ahve to have it dynoed to see where the powerband is at, its unique to each car.
While we are here why dont you tell everyone what you ran in my car??
Old 07-07-2004, 05:57 PM
KALEL's Avatar
lets just say it was worse than what i ran in mine..you didnt do to well in mine either
Old 07-07-2004, 06:11 PM
Yeah I know I was just giving you a hard time.
