Should i trade H/S rr for adj RR
Old 07-06-2004, 10:42 PM
destroyerSS's Avatar
Default Should i trade H/S rr for adj RR
should i trade in my new harland sharp RR 1.7 ratio for a set of adjustable RR? New rocker's must also be 1.7's due to piston to valve clearance. I am running a TSP 231/237 cam A/S 5.3 stage 2.5 heads with comp 977 springs and Comp "R" lifters, or should i just shim my Harland sharps. Install of heads will be finished this weekend so if i'm gonna order new rockers it has to be soon Thanks Shawn
Old 07-07-2004, 10:28 AM
Nasty N8's Avatar
I have used the HS with that exact setup many of times. There is absolutly no reason to use adjustables with the Comp R`s. It does take a little time to get them setup correctly but it works great.
Nate
