A/C blows softer after long period of time
Recently, I noticed on a long trip that after a while, my air conditiong would blow extremely soft even when set on max at the max blower speed. The air was ice cold, just not enough coming out. So I replaced the cycling switch after getting some advice from a friend that works at a GM dealer. I replaced the switch, and went on another long trip and noticed it happening again. This time it didn't happen as bad (was hotter outside, if that matters) but I could still tell a noticeable difference in blower force on max settings. Air is still ice cold, just weak...
It doesn't happen when I drive around town as much as when I drive steady hours on the highway...
Any ideas?
It's a 2001 Z28 M6 w/34k on the clock. Only engine mod is a lid.
Any ideas?
Moderator
Evap icing I'd expect, starting to obstruct the
airflow. Probably depends more on humidity
than air temperature. If you turn the 'stat
to a full-warm setting for a few minutes (but
still on A/C setting) and airflow gets better
again, this is your problem. Might want to not
use the full-cold-cranked 'stat setting, if it's
trying to force a sub-freezing output that
might be the root of the problem (A/C output
should be just above freezing so ice is not
formed).
formed).
Not necessarily - but it makes the compressor work too hard which is one reason the coils ice.
Originally Posted by TXAgZ28
But wouldn't low freon also produce not-so-cold air?
