Fueling & Injection - Fuel Tank pressure sensor
View Full Version : Fuel Tank pressure sensor
Payne
07-09-2004, 03:00 PM
Woud it be possible to seperate this from the stock in tank unit?
What are its physical dimensions?
If I had to put it in another tank, say a 1993 RX7 tank, how well would that work? Would I be welding a bung to the tank?
Or what about just attaching it to the inside of the tank, then drilling a hole, running a wire out of the hole, and RTVing the wire hole shut?
I am doing a CA smog legal RX7/LS1 and need to have the tank pressure sensor working, along with the evap canister.
Thanks!
-Jason
