PTV clearance? je pistons/ g5x2 .030 mill
Old 07-12-2004, 08:18 AM
mattz06's Avatar
Default PTV clearance? je pistons/ g5x2 .030 mill
will this pose piston to valve clearance issues?
forged 347 shortblock, JE pistons with 2CC valve reliefs (looks like they are like 1/4" deep reliefs or so)
milled afr heads (should be the same as milling ls6/ls1) milled .030 thousandths
2.02 1.60 valves
G5x2 cam 232/240 595/609 112
Old 07-12-2004, 10:39 AM
McRat's Avatar
You should have lots of room with factory reliefs in the pistons. Always check though.
