How exactly does the Gear Vendors Overdrive unit work?
How exactly does the Gear Vendors Overdrive unit work? And whats needed to install it? Is it worth the cash if you want overdrive on a TH400?
It takes a long time to explain these in detail. Here's a link:
http://www.fullsizechevy.com/forum/s...threadid=31459
BTW - awesome piece of 100% reliable bulletproof hardware.
Originally Posted by MeanWS6
great read - thanks for the link.
When in OD, does the GV unit screw up your speedo? Any PCM tuning issues when in OD and driving on the highway?
The PCM does not even know it's there. The GV does splice the Torque converter clutch circuit so it can unlock it for shifting, but when it does so it keeps the proper resistance on the circuit so the PCM does not detect a fault.
gv od
