Problems Bad or Real Bad??
somone help!! Problems Bad or Real Bad??
ok well i decided to go start my car and it started made some knocking noises for 2 seconds and died, wouldnt start back. checked oil, level was real high?? checked radiator, no water. pulled drain plug and i found the water and the oil. is it possibly a head gasket or cracked head or somthing else??? it ran fine saturday(last time i drove it since allen nelson custom tune) what could have caused this to happen?? Info would be helpfull, i guess i will pull the heads of tonight,
Wow, that truely blows. I just had a head gasket go out on me, but my car didn't die like yours did. I was able to actually drive it down the the mechanic. That's some bad feelings comming out of that story. Good Luck man.
Last time mine did that, I had a slow headgasket leak.
Filled up a cylinder with water overnight and it couldn't crank over.
Don't crank anymore or you could bend a rod or more likely just damage a rod bearing.
ok well i pulled my drivers side back spark( #8??) plug out and it was beat down into the spark plug??? im guessing this problem is real bad, i have the heads ready to come off as soon as i cut the headers loose from the y-pipe
ok well i got the heads off, OUCH, #8 cyl is beat to hell, the head of the valve broke off and put a whole through the head and filled the cyl up with water. should i check the bottom end out for more damage?? anyways i called the guys and patriot and so far the customer service seems to be great, they offered to fix the head for me, so that will save a little money,
Originally Posted by MelloYellow
Did the spring break on that valve? What caused the valve to bend?
well i got to lokking at the broken piston and i pulled a piece out of the middle and i stuck my finger through to see if anything under it was damaged, well i didnt feel anything so i tried to pull on the piston, it came right on out and crumbled into a glob or broken metal, the rod broke off it at the wrist pin, i havent found the rod yet, guess its probly in the block!!
Dude, there is bound to be more damage internally. Pull the pan, and check the rods and crank journals for scarring. How does a valve just break? What kind of springs are you running to pull a valve up with enough force to snap it? I have never heard of this before.
Was there any noise from inside before this? Sounds an aweful lot like you spun a rod bearing - but you typically will hear the signs of that coming.
Dan
Dan
