Current valve spring of choice?
Old 07-13-2004, 08:45 PM
Obliviously Obvious's Avatar
Default Current valve spring of choice?
Whats the current valve spring of choice?
I'm running GTP Stage 2X heads, and a cam that is a tad over .600 lift.
It's time to replace my cam with a better & bigger one.. springs need to go as well.
TIA
Old 07-13-2004, 08:55 PM
HumpinSS's Avatar
Patriot dual gold springs Sponsors over there ------------------------->>>>> have it
Old 07-13-2004, 09:06 PM
mrr23's Avatar
VHP dual springs. i run them in my car. sponsor on right. link to springs here. http://www.vincihighperformance.com/superwebdeals.HTML
Old 07-13-2004, 09:27 PM
pdd
pdd's Avatar
i agree
Old 07-13-2004, 10:36 PM
Woody's Avatar
Isky Gold
Old 07-14-2004, 12:44 AM
2 for Patriot..
1 for VHP..
1 for Isky..
Like I said.. I'm over 600.. do all of the above handle that ammount of lift? Any of them require anything special over what I already have?
I've already got retainers, etc.. I hope that I can just replace the springs, and not have to spend extra on stuff I already own.. unless I HAVE to.
Old 07-14-2004, 02:26 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Patriot Gold, Crane Duals or Comp 921's.
Old 07-14-2004, 02:51 AM
Gamble's Avatar
I believe my 918's are due for a swap. I'm hoping to go with 921's but there a lil' spendy... I'm sure and hope there well worth it though.
Old 07-14-2004, 03:01 AM
jrp
SN95 Director
jrp's Avatar
in that exact order as well.
calongo_SS's Avatar
I believe the patriots will require special retainers because they come with special (super 7) locks. I don't have them so i don't know how your retainers and locks will fit. Someone else chime in now to make up for my ignorance...
Old 07-14-2004, 08:41 AM
crainholio's Avatar
They do, but the kit comes w/ what you need and the price is favorable. Reusing old locks is bad practice anyway.
Old 07-14-2004, 10:14 AM
KJ
KJ's Avatar
I have the Crane dual valve springs in stock, along with tit. retainers, and spring seats. They are good to about .650 lift and would work great for your aplication. Let me know if you need some!!
Old 07-14-2004, 07:24 PM
Unaffliated Racing's Avatar
I run the 918's all day everyday with cams of a .615" and .050" before coil bind with no reservations. As far as harmonics and dynamics...nothing else compares.
Old 07-15-2004, 05:19 AM
Suspended Sponsor Account
ForceFed HP's Avatar
we are starting to use the Patriot duals, they are very nice and are of high quailty. we have some sets in stock ready to be shipped.
the crane and comp duals are also nice
all are reliable
Old 07-15-2004, 05:58 AM
Squintz Palladoris's Avatar
Give Roger a call he is great to do bussiness with!
Brad
Old 07-15-2004, 06:14 AM
PREDATOR-Z's Avatar
Another one for the PP "Gold"
I'm having them as an upgrade for my AFR's.
Old 07-15-2004, 07:25 AM
BRIAN98Z28's Avatar
Another vote for the Patriot golds, the 921s are great too but as some said are a bit pricey. Just depends on what your looking to spend, either one will do fine.
brian
Old 07-15-2004, 05:42 PM
kumar75150's Avatar
Originally Posted by Woody
Isky Gold
me too
.635 lift cam here
Old 07-16-2004, 02:11 AM
1LEFirehawk's Avatar
Which will work in a LT4 396 stroker? The cam is a custom ground Comp.
Int. Exh.
lift .540 .562
duration at. .576 .600
.242 .248
lobe sep. 112
Comp. hydrolic roller lifters and cam
pro mag rockers 1.5 and 1.6
202 valves
I need the springs to be good up to 6800 rpm w/o going to solid roller lifters.
Thanks,
Andy
Old 07-16-2004, 02:41 AM
Collections Hold
Cary@Perf-Induction's Avatar
Default springs
We use the Ferrea dual sport compact spring, never had a failure. 175 lbs on the seat, 450 open. The comp 918 springs are one of the best out there as far as stability and control. Seen a lot of testing on the spintron.
