removal of the fog light switch
Old 07-13-2004, 08:50 PM
andrew1's Avatar
Default removal of the fog light switch
how do you remove the fog light switch on a 98 trans am. i am replacing my gauge cluster and i cant find otu how to get the dam fog light switch off the plastic cover
Old 07-14-2004, 06:57 AM
STF Veteran
TA TED's Avatar
Pull the bezel off of the headlight switch module. There are two tabs on either end that hold the fog switch into the bezel. Push them in and remove the connector.
Quick Reply: removal of the fog light switch
