low timing table in first gear only? m6
i went to e-town dragstrip last weekend; first time in about a year or so.
it was hot; about 86 degrees. i was on slicks, but otherwise full weight and in road race suspension mode. i logged my first three runs, but timing in first gear never was higher than 18 or 19.5. (first run shows 25 but i think i was changing gears). i also think i was loggin too many parameters and the logging was pretty slow.
but it shows my low timing. can you offer any advise as to why this is occuring? here are my 3 logs:
http://www.angelfire.com/nj2/ponycars/efi.htm
LS1TECH Sponsor
Originally Posted by foff667
it was logging real slow on the one run i saw it jumped from like 4900 to 6500rpms from one frame to the next in first gear...i would assume if it would log a bit faster youd see a different set of #'s
