reading PCM flash files (not modifying them)
I was wondering if there is a way to just read what
flash file is in the PCM without purchasing a tuner
program? I have autotap and efilivev6pro so I can read some
parameters, but cannot download the entire
PCM flashfile,
Gert
PCM flashfile,
Gert
gotta buy a tuner for it... unless you were to get a chip reader, pull your PCM apart, desolder the Intel flash chip and do a dump if it's content using the chip reader... or build your own hardware (the VIA cable sells for 250 or so... I believe you can use it to access the PCM's flash memory) and make your own software for reading the PCM (difficult if you don't know exactly how to communicate w/the PCM)
Would be cheaper and quicker to get a tuner though (IE HP Tuners)
