leaky t-tops
Old 07-14-2004, 07:48 PM
jammon46's Avatar
Default leaky t-tops
i have had my 00' Z for about 7 months and when i bought it it came with a 3,000 mile warranty. the first big rain it was in, (sorry, i park my 66' chevy truck and 69' camaro in the garage) it was like a small swimming pool in the back seat. i took it to the dealer and they had all the weatherstripping replaced. i thought it was fixed, but nooooooo. last week there was water in the back floorboard but not as much. i know it happens to lots of t-top owners, so someone tell me how to fix it please.
Old 07-14-2004, 07:59 PM
Rick'SSOM's Avatar
I have the same problem,I dont use the sun shades anymore that seemed to help alot.Now I hardly ever get water.
Old 07-14-2004, 08:02 PM
jammon46's Avatar
i never use sunshades, but thanks.
Old 07-14-2004, 08:04 PM
~RedLineLs1~'s Avatar
My car NEVER gets wet on the inside when it rains...I get some drops on the seat when i wash the car though. And i thought mine was bad
Old 07-14-2004, 08:09 PM
John95Z28's Avatar
Do you have a set of subframe connectors installed? If not, you should get some. It might seem totally unrelated but stiffening up the chassis will help with squeaks and rattles, and even (so I've heard) T-roof panel issues. Even if it doesn't stop the rain from coming it, it's a worthwhile mod nonetheless
Old 07-15-2004, 12:04 AM
WhitePheonix's Avatar
Ditto, this should stop the leaks
Old 07-15-2004, 12:55 AM
tuffluck's Avatar
it won't stop leaks, because if your car is already warped (the frame) then subframes will only keep it from warping more; the existing warp probably won't change much, and if it does, it will take time to do so.
you should look where your t-tops seal to the rest of your car. if there is a gap in between the seal of the weatherstripping from the car and the top, you should take your t-top apart and adjust the weatherstripping accordingly. if you do this, you won't get water in you car due to having a poor seal anymore.
if all 4 seals look good, then it's a problem elsewhere. there are 1000 different possibilities. i would check the seals first. i solved my leakage problems by adjusting the seals.
Old 07-15-2004, 03:59 AM
Gamble's Avatar
I'm guess I'm fortunate that my car has yet to have problems when it comes to water gettin' in. I never drive my car in the rain so I hope it's sealed well.
Old 07-15-2004, 08:00 AM
JHTZ28's Avatar
I had SFCs installed on my car about two months ago. I never had a problem with my T-tops leaking, however after I had the SFCs installed they did fit much tighter. It was like night and day. The day that I got them installed I noticed it right away and have been happy with them ever since. I think getting a pair of SFCs will definitely help your problem if not solve it. Nevertheless, it definitely won't be a waste of money even if it doesn't solve the problem, b/c SFCs are a great mod for many reasons. Hope this helps and good luck.
Old 07-15-2004, 08:32 AM
pmh
pmh's Avatar
I had a leak start after taking mine off and on a few times. It wasn't bad just some dripping. I noticed that the window seal on the top and the windsheild post weren't meeting together correctly. I re-seated the top and the dripping went away.
pmh
Old 07-15-2004, 10:19 AM
badhoopty's Avatar
i dont know if it applies to 4th gens, but my old 2nd gen trans am would flex under torque so bad it would loosen the t-tops. i would adjust them and they would fit fine until i got on it again. so i agree with everybody else, get some sfc's and then adjust/tighten up the t-tops if the 4th gens allow that.
Old 07-15-2004, 12:27 PM
I through the alignment off with a few WOT's. My tops started leaking. I know if I had the SFC that wouldnt have happened.
Old 07-15-2004, 12:40 PM
ddelallata's Avatar
a little off topic......anyone know the part #s to the weather seals on the roof panels?
Old 07-15-2004, 03:24 PM
69_YENKO's Avatar
when i first bought my car '00 camaro (used - may '04) the head liner was all nasty, and hanging down around the edges. it looked as if water had got in from around the t-top area. but for as long as i have had the car (2 1/2 months ) it hasnt leaked at all. oh and i replaced the head liner with one that uses ABS plastic instead of a cardboard backer.
Old 07-15-2004, 07:31 PM
z289899's Avatar
But if the frame is slightly twisted can't he go and put it on a frame straitener that has the laser frame checkers and then get the sfc's put on?
Old 07-15-2004, 10:25 PM
John95Z28's Avatar
Yeah, I would think so. A shop with a frame machine should be able to check it, and correct any problems. Right after the car gets a seal of approval from the laser guided frame machine would be the perfect time to weld in some big, beefy SFC
Old 07-15-2004, 10:30 PM
SmokingWS6's Avatar
Sure the leak is not coming from your rear hatch?
Old 07-17-2004, 10:50 AM
z289899's Avatar
Yeah mine does the same thing, it is deffinately from the t-tops. My frame is so twisted right now it is not even funny. I have a couple inches in the passenger rear floorboard almost every time it rains. Try cleaning that up every time. The mildew smell is starting to really get on my nerves. Good thing it is coming off the road soon anyway!
Old 07-17-2004, 06:07 PM
02Hawk502's Avatar
Don't forget, you can always adjust the window so it is tighter up against the stripping. A lot of cars leak at the upper rear corner.
Old 07-17-2004, 08:01 PM
blackfang's Avatar
My ex fiancee's 00 Z/28 leaks as well. I also have a normal customer that comes to our shop that I service and her 02 35th CE Trans Am has been in 3 times and had everything replaced due to them leaking.
