V6 to V8 swap?
Old 07-15-2004, 06:29 AM
Dustin 98TA's Avatar
Default V6 to V8 swap?
Has anyone ever swapped an LS1 into a firebird? A buddy of mine has a wrecked 98 T/A and a 98 firebird, he wants to swap the entire drivetrain.
Im trying to decide if its worth it or not, I will probably have to do most of the work.
if anyone has done this, please tell me what is involved.Will the V6 K-member work?Will the wiring be the same?etc..?
Old 07-15-2004, 08:22 AM
99RedZ28's Avatar
Default ls1 swap
It can be done, yet it is alot, there is a member of www.fastlouis.com that has done the swap, here is a link to useful thread https://ls1tech.com/forums/new-ls1-owners-newbie-tech/180812-hey-guys-can-you-help-me-few-things.html
Good Luck man
Old 07-15-2004, 10:57 AM
Administrator
unit213's Avatar
It's not worth it especially considering the low price that an LS1 fbody can be bought for these days.
Old 07-15-2004, 12:09 PM
cyphur's Avatar
unless you're doing it for fun or for the experience.....if the car was wrecked take the insurance money and go find a nice t/a.
Old 07-15-2004, 12:11 PM
METALBEAST's Avatar
Old 07-15-2004, 12:24 PM
SSInnovations's Avatar
I just completed a swap with a friend of mine, LT1 into a 97 V6 Firebird though. Send me your e-mail adress and I can get you a list of everything that was needed/involved. To be honest, it gets expensive and is a a lot of work.
Old 07-15-2004, 01:28 PM
slow's Avatar
if you have the 2 car, both 1998's thats 1/2 way there.
if you have lift access, drop the K members, swap whole motor/tranny assemblys.
swap fuel tanks, and lines, and swap engine harnesses, jumper 1 wire to power to the coils, and you should be set.
I know there are a few steps missing here, but you have the best way to do the swap, full donor car, and same year (98 stays with 98's and 99-02 with 99-02 and you'll be fine for wiring/tank/ect.
Ryan
Old 07-15-2004, 01:44 PM
Thats what im debating on, he really wants to swap it over, and Im trying to convince him to sell it and part out the other one. He could go buy another T/A and start modding again.
Thanks for the replys,
Old 07-19-2004, 02:41 PM
John_D.'s Avatar
If you are thinking about doing headers, heads, cam, bmr k-member, etc., it's SO easy to do all that at the same time as the swap.
Makes the swap time just part of the mod time. It's not that bad of a job, if you can get the front of the car up. I put my LS1 actually into the car by myself. (had some much appreciated help with other parts of the job though...) The engine and tranny were on a low furniture moving dolly. Put the shock towers in first. Then jack up the k-member into the frame. It has 2 locating pins on it. Piece of cake...
Yes, getting power on pin B of the gray connector on the passenger fenderwell is the only thing that's not obvious. The LS1 has INJ1 and INJ2 circuits in the underhood wiring, and the v6 has only INJ1. It's just 12v power on one pin. You can jumper it from another 12v ignition switched wire. It feeds power to the injectors and the coils on one bank.
