sub-frame connecters
Old 07-15-2004, 08:34 AM
pmh
pmh's Avatar
Default sub-frame connecters
which ones are good and which are junk? Were can I get the good ones? I'd perfer bolt in, are they as good as welded in ones?
pmh
Old 07-15-2004, 08:39 AM
Ru2n00n3er's Avatar
I'm also trying to figure this out. The boxed design ones are supposed to be stronger than the tubular ones, but I don' t know how much. Then there are also the Kenny Double Daimond and SLP versions that has a more in depth design with cross-bracing. They're like $100 and I don't know if the different design is worth it.
Old 07-15-2004, 08:45 AM
Mystic's Avatar
I think the KBDD are alittle overkill. The tubular ones will be just fine so i wouldnt worry about the boxed ones over the tubular ones. If the price is right on a set of tub. ones buy them up. They say BMR's are nice but they are weld on. All SLP stuff is pricey.
Old 07-15-2004, 09:24 AM
kraut187's Avatar
Is there any real difference or potential problems with getting bolt-in SFC's versus the weld-in ones. I don't plan on going crazy with torque in the future so would the bolt-on's hold up fine?
Old 07-15-2004, 09:40 AM
Zo6Killer's Avatar
Bolt ons tend to be a little bit more pricey, and I've heard that they may come a little loose after awhile. Most competant shops can weld you in a cheap set of weld ins for fairly cheap. That's what I'd do.
Old 07-15-2004, 10:55 AM
SSCamaro99_3's Avatar
I have Global West welded subframes. They tuck up very nicely, and really made the car feel better.
Old 07-15-2004, 10:57 AM
Checkmate's Avatar
I have the SLP bolt in subframe connectors. They helped a lot.
Old 07-15-2004, 11:38 AM
pmh
pmh's Avatar
Does global west have a web site?
pmh
Old 07-15-2004, 12:22 PM
WhitePheonix's Avatar
Im thinking BMR Boxed, they seem to be a popular choice around here
Old 07-15-2004, 02:03 PM
Moderator
jimmyblue's Avatar
This subject, you would find a lot more info on by
searching in the Handling & Braking section where
it's been discussed many, many times.
Old 07-15-2004, 02:36 PM
pmh
pmh's Avatar
Well, I guess that I didn't do something correctly when I did my search, because when I searched in the handling and braking section for subframe connecters I got a wopping 8 results and only one of those comes close to answering my questions. I definately don't want the search police on my back, so jimmyblue, any help to this newbe would be great!
pmh
Old 07-15-2004, 02:42 PM
glennhl's Avatar
I bought some BMR Tubular "Copies" on Ebay for $100 and had them welded in for $115 at a local shop. They tuck up nicely and work great.
Old 07-15-2004, 03:06 PM
hourang's Avatar
i got competition engineering bolt in subframes for like $160 at ramchargers, i wasnt looking for a bolt on set but for the price it was cheaper than a lot of weld in ones, most bolt in sets i found were too much. they look like quality pieces, i havent installed them yet but when i test fitted the drivers side it went in nicely and tucked up there real good, wouldnt even know they were on the car. just need to find a good shop to weld them in, i wouldnt even consider bolting them, the metal is too thin on the inside of the car for my comfort.
Old 07-15-2004, 03:15 PM
Deeavi's Avatar
I bought the Edelbrock # 5290 Weld-on Connectors. I have had them for awhile. Just haven't had time to put them on. Actually going to try and put them on this weekend. They are supposed to be the best fitting ones!
Old 07-15-2004, 03:16 PM
Fast Eddie's 02 T/A vert.'s Avatar
I have the KBDD weld in SFCs, I don't regret it one bit,my T/A is as solid as the day I bought it.I also race it six months out of the year and the car is still solid.
Old 07-15-2004, 03:18 PM
It's not mine! woo hoo!
demonspeed's Avatar
I went with the weld on boxed BMR's. I like the boxed design because you can throw a jack on them anywhere to lift the car up.
Old 07-15-2004, 03:46 PM
slow's Avatar
try the search with the words SFC instead
Ryan
Old 07-15-2004, 11:11 PM
ace68's Avatar
i got a set of slp's, knockoffs, on ebay for 120 weld on they came with primer on them and i painted them yellow welded them in myself can't really see them unless your far away from the car he still sells them he has boltons too.
Old 07-16-2004, 03:13 AM
blkZ28spt's Avatar
yup. makes jacking up one side of the car for tire/wheel swaps so much easier when you can stick a jack unnder there, put a stand next to it if you like, and voila. Also tightens the car up nicely. Got my BMR's for $160 plus $65 for weld in install at LS1 Speed. Of course, my handling kind of took a hit when I removed the sway bar last week though I'd just get the boxed (as i did) they are stronger and hardly any more expensive and don't hurt ground clearance either.
Edit: Also, i dont see why you'd want "stealthy" SFC's, not sure if my ground effects (sport package, stock) affect it but mine are not visible and i have lower things than them anyway such as my exhaust, dumps, and two quart deaper trans pan.
Old 07-16-2004, 04:17 AM
mooleyz28's Avatar
Boxed and get them welded on. Quick easy and safe! GREAT MOD as well!
