Drag Racing Tech - Harlan 2-step installed today!
GeorgeC
08-06-2002, 07:43 PM
I did a few "tests" in front of the house, too... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Even with a 1.82 1st gear, the car feels reallllly nasty coming off the 2-step (set at 4K rpm) and brake at full throttle. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I'll try it out at the track tomorrow night.
AlonzoVersion 1.0
08-06-2002, 09:07 PM
I have heard nothing but good from these things.So are you going all out full throttle tomorrow?I want one but it seems to be a problem with 98's for some reason.
GeorgeC
08-06-2002, 09:25 PM
I'll probably make a couple of easy passes to make double sure things still look OK, but I do plan on some full 1/4 mile passes...
AFAIK, the only problems with 98's and the Harlan 2-step is with M6 cars, and that's only if you're using the clutch pedal itself as the activation switch.
CutlassRacer
08-06-2002, 10:18 PM
Hey George, I have marks both leaving my neighborhood and where we turned around coming back from Sonnys. That thing sure feels like an animal. If you want to see what it looks like going down the track I have no problem driving it for you <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> HA HA, man what a kidder <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
gator's 99TA
08-06-2002, 11:06 PM
how is it any differnt than normal launching other than you have a throttle stop? how is it making more power?
AlonzoVersion 1.0
08-07-2002, 03:39 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GeorgeC:
<strong>I'll probably make a couple of easy passes to make double sure things still look OK, but I do plan on some full 1/4 mile passes...
AFAIK, the only problems with 98's and the Harlan 2-step is with M6 cars, and that's only if you're using the clutch pedal itself as the activation switch.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks George was it hard to hook up?I am no electrical genius so if there is splicing involved then I may have to have someone else install it.
GeorgeC
08-07-2002, 06:13 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by gator's 99TA:
<strong>how is it any differnt than normal launching other than you have a throttle stop? how is it making more power?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Because it still lets the converter flash (to wherever it flashes to) when you release the transbrake/2-step. It's almost like a manual car in the sense that when the brake releases, WHAM, you're moving.
Kevin, I would let you drive, but I need somebody to run the videocamera. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
GeorgeC
08-07-2002, 06:17 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Alonzo:
<strong>Thanks George was it hard to hook up?I am no electrical genius so if there is splicing involved then I may have to have someone else install it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very easy install. The unit plugs into the factory coilpack wiring harnesses, and there is a ground wire, and an activation wire. That's it.
Reckless
08-07-2002, 08:24 AM
Sweet! I will be testing mine on Sunday at the track.
AlonzoVersion 1.0
08-07-2002, 10:40 AM
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Alonzo:
<strong>Thanks George was it hard to hook up?I am no electrical genius so if there is splicing involved then I may have to have someone else install it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very easy install. The unit plugs into the factory coilpack wiring harnesses, and there is a ground wire, and an activation wire. That's it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You shouldnt have told me that. <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
