how much oil does 98 ls1 take
Old 07-15-2004, 06:26 PM
98redz28's Avatar
Default how much oil does 98 ls1 take
ive always put in 5.5q an i was reading some where, that it took 6.5q is this true, thanks 98 ls1
Old 07-15-2004, 07:40 PM
felton316's Avatar
I put six quarts in my 98 with the small filter. I do not want it to starve for oil if I take a long sweeping turn.
Old 07-15-2004, 07:48 PM
John Yoder's Avatar
5.5 quarts in an fbody. 6.5 in a corvette due to the different oil pan.
Old 07-15-2004, 07:59 PM
mitchntx's Avatar
I run 7qts in my '98 TA
It's a ticking bomb running 5.5 ...
Old 07-16-2004, 05:33 AM
98boxer's Avatar
won't too much oil hurt the engine?
Old 07-16-2004, 08:35 AM
mitchntx's Avatar
Yes, it will.
We measured and the lower end of the pan will hold 7qts.
Here are some pics ...
5 quarts - notice how it covers the baffle, but is still contained in the lower end?
6 quarts - notice how it fills the slanted portion. Also, notice the "dimple" where the slanted portion and the shallow end meet? That is clearance for the crankshaft.
7 quarts - notice how the water just reaches that dimple. So, if the crank will clear the pan, it will clear the oil level.
Now consider subtracting from the pan's level what gets caught inside the motor and almost a whole quart in the filter and there is plenty margin.
Like I said, I run 7 almost al the time.
Old 07-16-2004, 08:38 AM
Moderator
davered00ss's Avatar
I would use 5.5 like the owners manual says.
Old 07-16-2004, 08:42 AM
Ackattack1's Avatar
I use 6 to acount for the 1/2 qt oil usage, and its easier than messing with a half of a quart.
Old 07-16-2004, 01:13 PM
Hagarr's Avatar
ditto- 6 quarts.
Old 07-16-2004, 03:38 PM
Boostaholic's Avatar
Always been 6 for me also
Old 07-16-2004, 05:02 PM
tensecondz's Avatar
Very informative pics Mitch,, Thanks
Old 07-16-2004, 05:20 PM
psychocabbage's Avatar
ya! great info!
I use 6qts since a mechanic at RSI suggested I do.
Old 07-16-2004, 06:26 PM
mitchntx's Avatar
The thanks goes to John ...
http://frrax.com/rrforum/index.php?a...27&hl=oil+pan&
Quick Reply: how much oil does 98 ls1 take
