Do Timing Changes Afffect A/F Ratios
Old 07-16-2004, 07:12 PM
Earl H's Avatar
Default Do Timing Changes Afffect A/F Ratios
Tuned the A/F ratio on the dyno. I wanted to take the car out on the street to test timing under load. If I add timing, will it affect my A/F ratio? Thanks in advance for the help.
Old 07-16-2004, 07:42 PM
LS1Tech Sponsor
Slowhawk's Avatar
From what I've seen when you add timing it richens alittle.Take timing out and it leans out.
Old 07-18-2004, 12:31 AM
moehorsepower's Avatar
Default A/f
Actually it is the other way around,I tune on the Dyno and adding timing will lean the Air/Fuel a little........
Old 07-19-2004, 12:33 PM
Red01Chevy's Avatar
id have to agree with him
Old 07-19-2004, 01:02 PM
LS1TECH Sponsor
foff667's Avatar
hmmm thats an interesting argument being slowhawk is a tuner if i remember correctly.
Old 07-19-2004, 01:09 PM
APeteSS's Avatar
Yes, when you advance timing, you'll (theoretically) get a more complete burn of the cylinder gases, thus decreasing the amount of free oxygen in the exhaust tract which gives a leaner A/F reading.
In practice, this is true but AFR changes resulting from timing changes differ from car to car (probably due to different head/CC design/location of spark within the cyl/valve timing).
Old 07-19-2004, 01:10 PM
APeteSS's Avatar
Slowhawk's smart. Is this an oversight, Hawk?
Old 07-19-2004, 02:10 PM
gonzo 6.2's Avatar
Here is what I noticed for me yesterday.Playing with a LM1 I was getting way fat like 10.2 A/F @WOT 28deg. westers tune running a KO box.disconnected the knock outbox running normal KSs,got 20 deg(lots of faulse Knock) WOT and 10.8 A/F.Installed my ED Wright PCM ,I get 28deg and 11.8 A/F @ WOT,Still to fat huh boys?
Old 07-19-2004, 09:30 PM
NoGo's Avatar
Ditto
Advancing leans, retarding richens. (as stated above)
It has to do with cylinder pressure and burn rate. Advancing timing increases cylinder pressure which results in an increased burn rate. The accelerated burn rate produces a more complete burn (as stated above). This will be true up until the point of detonation.
