The Juggernaut
08-14-2002, 06:35 PM
Is there anything special to putting on a new steering wheel?
Adapter hub or anything?
George C? or anybody else?
I was thinking of getting a Grant wheel.
zturbo
08-15-2002, 03:39 AM
Grant wheel will work fine.
Get a grant part #3196 (adaptor) You can get the nicer alum version as that one is the rubber covered one.
Then you can pick whatever grant steering wheel you want.
Steven
GeorgeC
08-15-2002, 06:26 AM
Ditto... You may need to use some washers behind the adapter to space it out from the column a tiny bit so it doesn't rub while turning.
