NEED help Please ... Headlight problem
Old 07-18-2004, 11:32 AM
Fierce-LS1's Avatar
Default NEED help Please ... Headlight problem
Me and my friends were working on my car yesterday. Then when I left my house and turned the headlights on, the lights actually turned on but they did not pop up (TRANS AM pop-up headlights). They did not even make a noise ... just stayed in their housing. It can't be the motor because it would either grind or only go up halfway.
Is it possible some wire accidentally got disconnected ? If so ... can someone point me in the right direction ?
Old 07-18-2004, 11:40 AM
Mean Machine's Avatar
well....you might want to check the weatherpack connector that goes to the headlight motor. i had the same problem last year, light would come on, but wouldn't pop up. turned out there was corrosion inside the connector. good luck.
Old 07-18-2004, 02:18 PM
dubs6's Avatar
had the same problem last week thought it was the motor but turns out it was just in a dead spot. i messed the manual remote thingy(behind the headlight) and now it works fine. i have also heard of the connectors failing or disconnecting.
