Do 6.0 truck heads flow better than 5.7 LS1 heads?
STF Veteran
I was wondering if the 6.0 truck heads flow better than the 5.7 heads right from the factory.
The reason I as is would it be any improvement in power to switch to a set of stock 6.0 liter heads from my stock 5.7 liter heads.
the LQ9 heads flow better, as they are a big chamber ls6 head. i dunno if it would be worth the swap though, seeing as you would loose compression. they work well in forced induction apps though.
my understanding is that they are the exact same design as the LS6 head with a larger CC chamber to lower the compression ratio (agreement). Unless you are doing something to maintain your current compression ratio, or increase it I would not do it. Lower compression ratios have a lower volumetric efficiency at all RPMs and you will lose horsepower and torque across the band, and maybe gain a little way way up in the RPM band due to better flow...maybe. I would love to see a dyno chart, but I doubt you would like to see it. It would suck. I think the amount you would have to shave would be too much, which is why the head companied that use them fill up the extra space with some filler or weld or something. You could switch pistons though. Now if you are going for a blown application, yes they would work out awesome. But...you would probably still want to replace your pistons so you don't blow a hole in one (or more).
SN95 Director
and check my cam guide for the stock flow numbers.
Originally Posted by ls6jimmy
0.30 will give you 10:1 compression and you wouldn't have to modify your intake. And you could take as much as 0.70 but your intake would need modification's
So would your pistons, extra valve reliefs. .070"off heads with any cam would come up shy. Do a search about 6.0 vs. ls6 heads because there is a intake port design difference. Someone has chimed in about this in the past, maybe Brian Tooley from TEA.
SN95 Director
Originally Posted by JZ'sTA
Yo jrp I read the whole thing, no where did it show stock head flow numbers.
http://ourworld.cs.com/jrpws6/heads+...ckheadflow.jpg
STF Veteran
lol, im a dumbass, your right. i though i put that **** in there but i didnt. was gonna make a head guide as well but never got around to it. anyway here it is:
L/D
Full CFM
Test Pres
Flow Pres
Corr CFM
I could have SWORE that LQ4's (9.4:1, "regular" truck motor), and the LQ9 (10:1 Silverado SS, Caddy SUV motors) all use the same heads?
The compression from my LQ9 comes from flat-top pistons.
