SLP Roll Master Timing Chain
I took a lok there, it only mentions how and when you should replace the chain. It does not mention anything about how you remove/install the new gears for the crankshaft. That is what I am interested in. Can you use just a pullie remover to take of the gear? What do you do to install the new gear onto the crank?
Originally Posted by PREDATOR-Z
Then let a shop do it.
