Help with comp R's!
6 Second Club Moderator
Help with comp R's!
Someone has to know of a cold setting on the comp R's. It says pre load of 2-4 thou. Hot. But setting them up cold, whats the magic number? The grow rate on the block can't be that different from engine to engine. I have adj. shaft mounts so I want to get them right. Someone has to have done enough of them to know what to set them up cold. Thanks Andy.
1/4 to 1/2 a turn is what I turned up when I searched for this info. I have done two motors this way and it was succesfull. The only way to tell how much preload you have is to put a dial indicator on the rocker just over the pushrod and measure when you tighten it past 0 lash.
Brad
Brad
