TSP225 cam What should I set the rev limiter at?
Old 07-26-2004, 05:50 PM
BriancWS6's Avatar
Default TSP225 cam What should I set the rev limiter at?
I just installed a TSP225 cam, Patriot gold dual springs, titanium retainers, hardened springseats, TSP hardened Pushrods, and March UD pulley over the weekend. I am going to get a tune Mon Aug 2nd at TEA. Before then I want to play with the rev limit and shift points with the HPPIII. What would be a good # to set the limiter to for good pull and to be safe also. If the stock cam peaks or flatlines at 5500 and the limiter is set at 6250, and if the TSP225 peaks at 6000, then would 6700 or so be okay? Maybe 6600 and adjust each shift point until it taps the rev limiter and then bump the limiter up to 6700? Any thoughts or suggestions would be appreciated.
Old 07-26-2004, 07:09 PM
CamaroCain's Avatar
That is kind of what i was thinking. Have you talked to the guys at TSP yet about this? I'm sure they could help you out.
