Header Install Problem
I started a headers install, got the manifolds off and went to put the header in and the steering elbow is in the way and i cant get it off... took both of the bolts off and it still wont come off and it seems that this is blocking the header from going in... and the tab on the block that has to be shaved... How do i go about getting the steering elbow off?... or any other tips would be helpfull... we were so damn close...
Thanks
Bryan.
Thanks
Bryan.
If I remember right it slides up on the top part of the steering shaft and then you can pull the bottom part out. Once the bottom is out the top slides right off. Also there is a bolt on the top and the bottom so make sure you get them both. Its pretty easy once you do it one time.
Mine is being a bitch... its stuck between the steering elbow, the tab on the block, a head-bolt and a piece of the underbody of the car... so im hoping that once we get the steering elbow out it will go a little smoother.
