what do u guys think of my new setup??
Old 07-27-2004, 06:33 PM
pdd
pdd's Avatar
Default what do u guys think of my new setup??
itll be done in a few weeks. afr 205cc, fm11, nicks 90mm TB, fast 90mm intake and the stuff in the siq. any problems u guys see with this setup?
Old 07-27-2004, 06:44 PM
KGSloan's Avatar
traction
should be a nice setup
Old 07-27-2004, 07:04 PM
kickassT/A's Avatar
only problem with it? it's not on my car. lol. should be a killer setup. let us know how it turns out
Old 07-28-2004, 07:02 PM
pdd
pdd's Avatar
wow. not many opinions. like if ill loose midrange or have more top end. or?
Old 07-28-2004, 07:12 PM
Brian2001SS's Avatar
It might be to new of a combo to know exactly what it will do. Those AFR heads look good, but still to new to the ls1 seen. Looking forward to seeing some numbers.
Old 07-28-2004, 07:39 PM
Ragtop 99's Avatar
the intake & tb will work on your current set-up.
If a shop is doing the work you're looking at as much as $2k to swap to the new heads ($1k labor + $1k net for the new heads). It will be interesting to see the gains. How about doing it in steps so we can see the gains from the heads seperate from tb & intake.
Old 07-28-2004, 10:02 PM
pdd
pdd's Avatar
im doin the swap myself.
