Hey auto guys, what's your voltage???
My wife's '00 TA is an A4 and her battery voltage sucks *****. I just replaced her battery today with a Red Top Optima battery, since the GM battery started to leak acid all over the garage floor. Here's the break down of her voltage....
WITH OPTIMA:
Idle in park with a/c off: 13volts barely
Idle in park with a/c on: 11.5-12volts
Idle in gear with a/c on: 11volts maybe, right above the yellow area
Cruising down street with a/c on: 12volts area
When it's REALLY hot outside and you are at a light with the a/c on it will be at the line where the yellow starts. What the hell is going on here?
My SS (6 speed) will idle over 13 volts all day long. I know it has less load, but are all A4's this shitty?? I plan to get a Yukon alternator for her car, but just want to make sure nothing else could be wrong. I may need to replace some of the wiring, the flat metal thing that the terminal bolt goes through is yellow and discolored due to the corrosion, so I may need to get a new one of those.
Thanks for any help!!!!
WITH OPTIMA:
I run normally at 13.8 volts in park or drive at a stop. only time it dips is when the a/c is on and the cooling fans are on high, then it'll drop to just above the yellow in drive at a stop. 12 volts or so. This is normal. but it sould go back up past 13 as soon at your over 1000rpm or so.
Sounds like you alternator needs to be replaced and or the battery acid ruined your cables.
Originally Posted by Orange Peel
Yeah hers isn't that high in park either. I am most likely going to get a Yukon alternator that is 160amps, and be done with it. Damn A4's
