Th400 or Th350 D/S?
Th400 or Th350 D/S?
Does anyone make a D/S or can i swap a drive shaft out of somthing else when i do the 350-400 swap from my T56? I already have a race shaft so if i have to i'll have mine cut down. Thanks.
Thats what im saying i have been reading so much about this i have all the parts coming in except the driveshaft i dont know what to order or to have my stock one lengthened shortened the driveshaft is the only thing holding me back right now
Originally Posted by MYTURBOT/A
Yea, I guess if your post ain't flame bait nobody cares.
JUST DO IT YOU SISSY
figure out the "little" things when my 6spd is out
There are two TH400s, one with the long tail, the other is short. I am using the short, so I have to have one custom made. It will need to be lenghtened to 44" since I am using a 12-bolt. It is best to get a custom one, rather than stabbing anything in that will work. If you just get anything, chances are you might bind and damage the trans, driveshaft or rear-end. I am not taking that chace, since my Z28 will be a full-out race car. If you feel comfortable enough to just stab something in, I have heard that a T56 driveshaft will work on (IIRC) long tail shaft TH400. As for the TH350 ... I don't know.
