KD tools valve spring compressor
do you guys know if this spring tool will work with dual springs??I thought I read somwhere that they only worked with single springs...I'm doing a spring swap soon and need to know if it will work...
you can modify an autozone crowbar type compressor to work well. I made a jpg with pics and instructions. pm me with an email address and I'll send it to you
Vinci "VHP" valve spring tool available on web www.vincihiperformance.com Beware of home made lever type tools. They place serious load on the pivot bolt or stud boss and can bend small daimeter valves and crack valve guides.
Originally Posted by busavette
I used a KD tool to put patriot duals on my heads with no problem,the heads were off the car.
Dont get me wrong, the KD tool is a great, inexpensive tool for single springs, but i couldnt get it to work on the duals.
Originally Posted by 99ls1guy
this is what i did. worked perfectly for me. im glad i didnt waste my time or money on the other tools
