Adj. timing Chain question
Old 03-24-2003, 06:09 PM
JRcamaroZ28's Avatar
Default Adj. timing Chain question
I have a TR227/224 112 cam w/ 4* advance ground in. I chose this since i have the stock 3.42's and wanted a little bit more down low but I'm looking at a set of 4.10's and now i may want to retard it back to maybe only 0-2* so i can have a little bit more up top where the gears may start falling. Now is there any place I can find the isntructions on how to set up the ADJ. double roller or do the instructions come w/ the set. i'm looking at the timing set from SDPC (SDCS1160). Thanks in advance
JR
Old 03-25-2003, 08:44 AM
HITMANSS's Avatar
Default Re: Adj. timing Chain question
The instructions come with the timing chain. Usually it's just a matter of using the correct offset bushing.
Be aware that not all timing chains & gear sets are adjustable. The Cloyes and Comp Cams are adjustable, but don't know about other makes.
Old 03-25-2003, 08:55 AM
CamSS00's Avatar
The slp double roller comes with instructions on how to adjust it. It adj I think 2-4-6 degrees of advanced and retard. For the ?? about top end I would maybe thunder and see what they say. I have 3:73 with my 230/224 and it pulls hard all the way till I shift.
Old 03-25-2003, 09:08 AM
Thanks for the info. here is the one I was looking at it's in the LS1/LS6 section of there catalog and I also saw that someone else on here used this one since its adjustable. Maybe if someone could take a look and tell its the one I want befor I order it. It looks like the same one SLP sells.
http://www.sdpc2000.com/cart.asp?act...2267&pid=90940
JR
Old 03-25-2003, 09:21 AM
CamSS00's Avatar
JR it looks like the that I put in my car. I think the one that slp sells is made by roller master. Not sure. That looks just like it though
Old 03-27-2003, 11:17 AM
robertbartsch's Avatar
...i just ordered the sdpc double roller unit....it is nice and cheap ...hope it works well...
