Drag Radials with stock LCAs??
I may have the opportunity to borrow a set of Drag Radials next Sunday when I go to Silver Dollar Raceway. I have stock LCAs though, will the DRs improve traction and times; or will it be worse due to worse axle hop from the sticky tires?
Re: Drag Radials with stock LCAs??
You should not have any problems at all.
I have ran ET Streets and now I'm using Hoosiers Drags and have no axle hop on stock LCA's. I'm pulling low 1.6's.
What ever you do, if it starts hopping please stop or you will tear things up.
