If you install a cam on an early LS1, consider removing EGR.
Old 07-31-2004, 10:09 AM
Another_User's Avatar
Default If you install a cam on an early LS1, consider removing EGR.
I had been avoiding removing EGR for a long time, but I kept reading and thinking about some of my many problems, so I removed it. The problem is that with my Hotcam I was getting too much exhaust gas. Because the cam casues reversion (it's own EGR), plus the EGR wants to dump even more exhaust gas in there, I was way down on power. It was making me run lean down low, probably hotter than I needed to be, and now that it is gone...nice SOTP increase (yeah, yeah, butt-o-meter). I just wanted to share because if you search for EGR removal there are some posts that say don't do it. It should say don't do it, unless you have a cam.
Old 07-31-2004, 12:10 PM
ttujason02's Avatar
yea crap, I guess I need to do that. will just have to spring for the hptuners.
Old 07-31-2004, 12:44 PM
Ferocity02's Avatar
Some of us have to keep it
Old 07-31-2004, 02:14 PM
I just did an HPTuners delete via the PCM. Works perfectly, and then I disabled the EGR DTC and check engine light. Shouldn't be a problem if you get emmissions tested. If so, just turn it back on for the test, and then turn it off again.
