Is this normal 1-2 shift
Old 07-31-2004, 11:51 AM
02WS6Bird's Avatar
Default Is this normal 1-2 shift
at WOT the car will scream all annoying like bcuz of the LM and such...it gets outa hand but when it shifts at WOT from 1-2 it like SPITS...like a loud like burst of exhaust flow or something?
Old 07-31-2004, 12:14 PM
Spl170s's Avatar
Rev Limiter? If you hit the rev limiter at WOT, you will get a "sputter" type of situation with a sort of back firing sound.......sounds like you need to get your shift points worked over?
Old 07-31-2004, 12:19 PM
02WS6Bird's Avatar
the thing is that its a nice HARD SHIFT....like it doesnt slow the car at all...it pulls hard as f*ck...its jsut a weird sound....it doesnt do it so much from 2-3 and even less 3-4...its most noticeable from 1-2 tho...cuz in 1st it screams 2nd-3rd it roars...i guess....its wierd but its not a problem ive heard it on other cars b4....but theve all had headers and also....they mighta had M6's i dont kno for sure
Old 07-31-2004, 04:18 PM
Spl170s's Avatar
Your A4 computer controlls the shifting at WOT....if they aren't right......it will hit the rev limiter before shifting causing this problem.
A manual is all up to where the operator shifts at...totally up to them.
Computer controls everything....i am jsut assuming it is your shift points interferring with the rev limiter RPM setting.
