Wiring Problems Need Help From All!!!
I did the wire removal on the passanger side fender well and ended up with a couple of problems and need help fixing. My a/c wont blow out the front vents and isnt blowing cold air. My traction control wont work but the light is always on the gauge cluster. I took it to the chevy house and they told me to give them $450 and they will fix it, so of course i get mad and almost get into a fight with the owner cause he more or less called my car a peice of ****. Come on guys i need help to fix this, maybe you could just tell me where the wires run to and i could fix it or just show me a diagram or something.
thanx for the help,
josh
thanx for the help,
josh
The AC problem is the little vacuum line that runs back along there. It controls the vents (floor/defrost/blow). The traction control is going to be the wires connecting to the accellerator control servo (by the battery). Follow those wires and see if you left them disconnected somewhere.
I have every thing connected and i looked at the back of the traction control and there is a black wire with a white stripe on it well i was looking and i found a wire just like that by the fuel injector on the drivers side that is not connected to anything so i just need to know were it goes. Were is this vacum line your talking about i cant find it.
