need a little advice
Posted this on MOFBA and would like some additional input.
Just trying to learn and see what I need. My engine is where I want it for now 431/417 rwhp
took it to the track with street tires, stock clutch, shifter and rear end, cars best time of 12.6 @ 114 with 2.1 60' time.
I will get the clutch / shifer / 12 bolt with 4.10's in the next couple of months. So after that what do I need?
I want to be able to run on the track and also would like to improve handleing for mountain roads / cornering
So what are all of these for? and what application do they work best on like track vs cornering. any suggestions on combinations would be great.
Adjustable Shocks / Lowering Springs
subframe connector
Lower control Arm / relocation bracket (is there an upper control arm?)
strut tower brace
k-member
driveshaft loop
torque arm
adjustable panhard rod
front/rear sway bars (do you remove the front one for track runs)
lower A arms
BMR trac Pak ( i know this is a consolidation of some of the above)
spanner wrench
thanks
John
subframe connector
strut tower brace
k-member
driveshaft loop
torque arm
lower A arms
spanner wrench
thanks
John
"The Drag Racing Director"
Re: need a little advice
Jhon,
It sounds like you are headed in the right direction. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Give Madman a call #281.449.8833 He can help you out. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
<small>[ October 16, 2002, 08:30 AM: Message edited by: Coach 02 M6 Z/28 ]</small>
