Drag Racing Tech
To stall or not to stall....that is the question....
Old 10-22-2002, 08:40 AM
BLKWS6's Avatar
Default To stall or not to stall....that is the question....
I have a 2800 stall 'verter in the T/A. When at the track, should i stall it up to 2500 (and it will) or just leave at around idle? so far, i'm having issues with the 1/4 times. When i say issues, on my dyno sheet, i put down 394/422 and best i have had it so far is 13.01 @ 106 w/1.8 60ft. Before my cam/Ls6 int/verter i ran 12.90 @108 w/2.0 60ft & 316/337 rwhl. just trying to see why i cant run what i should be.
Old 10-22-2002, 09:35 AM
boomcase's Avatar
Default Re: To stall or not to stall....that is the question....
Try it both ways somecars like it some cars dont.
Old 10-22-2002, 10:03 PM
KatfishRacing's Avatar
Try stalling to about 1500 or a little higher. Gets you a little closer to the power band, but still allows the converter to flash.
