"Low Oil" light wont go off
Old 08-04-2004, 01:55 PM
Fastt Gunn's Avatar
Default "Low Oil" light wont go off
Popped on today while driving back from a customer's location. Pulled over and checked the level. Was a little more than a quart low. Went to the gas station and put in 1.5 quarts.
The light is still on though
And, I've never seen it come on for for being a quart or so low before. Matter of fact, I've never seen the low oil light come on at all... ever
Oil pressure looks normal. Level is full. Light still on....
Any ideas why?
Old 08-04-2004, 02:05 PM
Raped-Ape's Avatar
my car was doing the same thing, but everytime i checked the oil , it was ok, then one day i was underneath the car for something, and noticed that the sensor came unplugged from the oilpan
-jonny
Old 08-04-2004, 02:11 PM
Fastt Gunn's Avatar
-jonny
Hopefully mine just came unplugged too
Gotta crawl under and take a peak....
Old 08-04-2004, 02:14 PM
m1key99WS6's Avatar
After you fill it back up it won't go off instantanously, the car has to sit for a little (15 mins,etc) so the oil can settle back down and the stupid light will go back off.
Cheers.
Old 08-04-2004, 02:48 PM
bill99hawk's Avatar
Also try a PCM reset if your sensor is plugged in.
Old 08-06-2004, 11:37 AM
bad0211secws6's Avatar
also unplug your connecter and check for corrosion on the terminals
Old 05-28-2010, 10:23 PM
Youshallgofo's Avatar
thanks for the help with this 6 year old thread. =D
