No ABS or TC with 12 bolt, easy?
Getting a 12 bolt. Don't want to mess with ABS or TC. Do I just put in the 12 bolt do away witht the sensors and live with the ABS light or is it not that simple.
10 Second Moderator
so no problems doing this. will the brakes still perform ok just no anti lock? whats needed if you dont use the abs connection? just an abs light? im thinking about buying a moser housing and then buying piece by piece until i get everything. thats easier for me to do than trying to save $2200+ dollars
I just installed a rear end with TCS in my non TCS car yesterday......long story! Anyhow, what I did was not hook up the abs sensors and thought "ok I can live with the ABS light on" ....well not only is my ABS light on but so is my parking brake light and every time I hit the brakes for the first time ,after start up, the pedal makes the ABS cycling noise then doesn't do it again.
