1.8 Rockers lame question
Old 08-04-2004, 10:27 PM
WS6 RULES's Avatar
Question 1.8 Rockers lame question
What does it mean and do I have these on my 02? Is it a ratio of some kind of the rocker arm? Was looking at a camshaft to buy and it says it won't work with 1.8 rockers. Thanks
Old 08-04-2004, 11:39 PM
Unaffliated Racing's Avatar
The stock ratio is 1.7, if you change to a 1.8 ratio the valve lift will increase about .030". That's why you need to get the approiate cam for the rockers you will be using. Otherwise you might run into a coil bind or piston to valve clearence problem.
Old 08-05-2004, 11:04 AM
WS6 RULES's Avatar
Thanks for your help.
Old 08-05-2004, 03:39 PM
4mula's Avatar
1.80s raise the ramp rate.
Old 08-05-2004, 04:20 PM
Boostaholic's Avatar
Rocker ratio shouldn't change the ramp rate, it just changes to overall lift evenly over the lobe, ramp rate is still going to be the 1.7 curve, multiplied by 1.1.
Old 08-05-2004, 07:01 PM
it won't change the ramp rate at all but it will add about one degree of duration..something that you will never notice.
