Drag Racing Tech - Not so happy with results
nikon1999
08-05-2004, 05:33 PM
I installed 3.73's in my car from 2.73's, ran ET Streets on the car instead of the stock GSC's, and was expecting to hitt 12's. My old best before gears/tires was a 13.28@105.9 on a 2.1 60'. With gears/tires i made 3 passes.
13.8@105.6
13.39@105.7
13.29@105.8
Needless to say im a little unhappy with the results :bang:
TexMax
08-05-2004, 05:39 PM
What were your reaction times before and after? My best guess w/o seeing a timeslip would be that your takeoffs were worse after the mods.
artic-z28
08-05-2004, 05:57 PM
converter + tune = 12.5's probly better
BlueSix
08-05-2004, 06:06 PM
stock converter + ET streets = poor results.
nikon1999
08-05-2004, 09:07 PM
one problem is i couldnt stall the car past 1500, the brakes wouldnt hold. The car is tuned, but it was short shifting first a little bit. Maybe need to adjust the shift points a bit. A converter seems to be a must now.. the car has it up high but needs more help getting there. Get its big butt movin :poke:
SilverGhost
08-05-2004, 09:27 PM
what is with people not posting any damned needed info around here lately when asking a question:bang:
hard to comment on the before/after comparison without knowing the sixty foot on those et street passes...
SilverGhost
08-05-2004, 09:30 PM
this is the second thread i've looked at in 2 seconds where you've said this and it is not correct. are you confusing r/t with sixty foot?
BlueSix
08-05-2004, 11:10 PM
I was wondering that same thing. :huh:
nikon1999
08-06-2004, 05:45 AM
sixtys on street tires ranged from 2.11-2.18
sixtys on et streets ranged from 2.03-2.12
artic-z28
08-07-2004, 04:51 PM
i pulled 1.8 60ft's on sumos street tires
Quickshotkimber
08-07-2004, 05:05 PM
What size were the ET streets? You are giving back gear if they are taller than your stockers.
How wide are they? I think they are costing you more up top than they are helping you down low. A nitto or comparible DR is all that you need at your power level. Anything more is overkill and will slow you down.
Just my 2cents
thechef
08-07-2004, 06:45 PM
what psi are you running the et streets at???
Noyzee
08-09-2004, 12:34 PM
the weather was about 80* with very high humidity! The car short shifted with the et streets for some reason, and the car just wouldnt stall. we get the brake thing fixed and a stall the thing will fly.
id say converter and a nice set of drag radials and 12.5's for sure!!!
LittleBoyBlu99
08-11-2004, 08:26 PM
:secret: Sounds like your shift points need to be redone. Find someshop with LS1 edit or Hp tuning and this should make a big difference. :cheers: one problem is i couldnt stall the car past 1500, the brakes wouldnt hold. The car is tuned, but it was short shifting first a little bit. Maybe need to adjust the shift points a bit. A converter seems to be a must now.. the car has it up high but needs more help getting there. Get its big butt movin :poke:
