lsx and kooks headrs help pls.
Old 08-06-2004, 07:55 AM
FireHawk22's Avatar
Default lsx and kooks headrs help pls.
Hi all ..
1-from wher i can get the 01+ coolant pipes for my 90mm throttel body.
2- and about the kooks headrs do the stoke bolts work or i have to change thim.
and from wher i can get thim.
thanks for help.
Old 08-06-2004, 04:42 PM
kpowr82's Avatar
The stock manifold bolts will work, but you might want to replace them with some new stockers or header studs from ARP. I got the header studs myself but only ended up using two on each side. I've heard of guys having the stock manifold bolts break off switching back to stock or to different headers later on.
Old 08-06-2004, 05:00 PM
KJ
KJ's Avatar
Originally Posted by FireHawk22
Hi all ..
thanks for help.
SDPC is your one stop shop!! We have the 01 and up coolant pipe & plugs. We also stock a large amount of Kooks and are having a sale with free freight on all headers!
As for header bolts, I would recomend the ARP header studs. Very clean install, and works a little better than your stock bolts. We have ARP in stck also!!! Let me know if I can help!!
Old 08-06-2004, 07:10 PM
FireHawk22's Avatar
yes how much will thes cost and i realy need thim if you can let me call you that will be batter for me can you give me your name pls .
thanks for your help .
Old 08-06-2004, 07:55 PM
kpowr82's Avatar
Check his signature at the bottom of his post. His number and extension are there. Good luck with everything.
Old 08-06-2004, 07:58 PM
FireHawk22's Avatar
thank you kpowr82.
