BUDGET RACERS COME ON IN!!! ( New specials from FASTECH!!)
Ok guys and gals, here's the scoop. We are bringing a whole new line of packages and products to our customers. These are in addition to our current lines, but are aimed at helping you achieve your goals without breaking the bank. In honor of our pending grand opening and to promote these new lines, here are a couple of specials to get things rolling.
BUDGET CAM SPECIAL $899 INSTALLED!!!!
Included at this price:
Comp XER lobe cam (specs determined by your application)
Comp Cams 26-918-16 springs
Hardened Pushrods
Necessary Gaskets & New crank bolt & Coolant
Installation of components on your vehicle
We can also upgrade this package with items like one of our F/A series cams or an all out valve spring to make the ultimate cam package to suit your needs.
BUDGET HEADS & CAM PACKAGE $2995 INSTALLED!!!!
All Items from Cam package above
Custom CNC LS1 cylinder heads ( 302 cfm @ .600 lift )
Felpro head gaskets
New GM head bolt kit
These specials are only good through our grand opening date, AUG 21. We must recieve deposits by that date. If you have any questions or would like to set up an appointment feel free to give us a call 972 288 9500.
Hardened Pushrods
Felpro head gaskets
