Affordable rotating assemblies are just around the corner!
Old 08-06-2004, 09:46 PM
tbyrne's Avatar
Default Affordable rotating assemblies are just around the corner!
SLP is putting together some low cost but high quality rotating assemblies that can be used with GM's LQ9 iron 6.0-liter block. 383 and 402 cubic inch displacements will be available. Here is a quick rundown of what they are producing and what we will have to offer -
ZL 383 - low compression -
4.000" 4340 forged steel crankshaft, balanced to rotating assembly
3.899" heavy-duty, high-compression 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
383-CID displacement
9:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
Designed for forced-induction applications
Includes new rod and crank main bearings
ZL 383 - high compression -
3.899" 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
10.8:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
Designed for naturally aspirated applications
ZL 402 - low compression -
6.125" I-beam rods
ZL 402 high compression -
6.125" I-beam rods
More details for each of these can be found on our website. Pricing for each kit is $2499.99. We're currently taking pre-orders and should be able to start shipping around the 1st of September.
Order line - 1-877-4-TBYRNE
Send us e-mail
Old 08-07-2004, 06:08 AM
Billiumss's Avatar
6.125" I-beam rods
6.125" I-beam rods
6.125" I-beam rods
6.125" I-beam rods
Send us e-mail
Can you do better on the price Tom, check out this link....
https://ls1tech.com/forums/sponsor-sales-specials/195791-eagle-stroker-kits.html
Old 08-07-2004, 10:21 AM
tbyrne's Avatar
That's not the same kit.
Thanks,
Tom
Old 08-07-2004, 10:55 AM
tbyrne's Avatar
Oh yeah, there was a typo above. It should have said -
ZL 402 - high compression -
4.000" 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
402-CID displacement
11.3:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
and
4.000" heavy-duty, low-compression, 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
Old 08-08-2004, 01:33 AM
Restricted User
CAT3's Avatar
Tom, are there any plans on getting a Alum 402ci going? Thanks.
Charlie
Old 08-09-2004, 07:29 PM
tbyrne's Avatar
I'm not aware of any at this time but who know what will happen with the LS2 motors
